Superb Vag Com Kodlama
    • İleti: 7266
Not: Kodlama listesi www.stemei.de sitesinden alınmıştır. Kodlamalar sonucunda ortaya çıkabilecek herhangi bir sorunda sorumluluk size aittir. Öncelikle alttaki linkteki konuyu okuyun lütfen:
http://www.skodaturkey.com/showthread.php?t=28734
*Superb 2 Kodlama Listesi:
1. Columbus’ta hareket halinde video izlemek:
1.Ignition and engine on
2.Insert DVD and start the desired movie
3.On the steering wheel, press the voice button (who has no MFL, pressed a pinch the small "i" button on the top right of the speaker icon at the RNS) -> 3-tone chime sounds
4.Immediately on the RNS 510 "TONE" button (bottom left) -> Gong and another signal sounded together
5.The frame of the movie will freeze briefly and plays after half a second further
6.Start driving!
DANGER
§When changing the radio mode - whether via button or voice command (NAV, MAP, ...) this activation is automatic, so disabled will be reset to the original setting!
§To reactivate the vehicle must again resting (so think twice before)!
§Navigation and DVD-activation function together perfectly and without sacrificing speed, normally plan a route just before this intervention and start route guidance!
§The activation has on all other controls and displays in the MFA + no influence!
Function depends on the firmware version of RNS510. Works for 2660 and 2680
2. Columbus Gizli Menüyü Açmak:
In the navigation control unit gives you the option when Skoda Superb 3T unlock the hidden menu of RNA 510th
The following code is to be applied:
1.Select STG 37 (navigation)
2.STG adjustment -> function 10
3.Channel Number 50
4.New to this set: 1
5.RNS reset
6.The hidden menu can be opened with the key combination Setup (hold very long pressed -> see also video)
3. Aracı kilitlerken kornanın çalması:
In the central electrics You have the option at the Skoda Superb 3T the DWA to acknowledge (alarm system) when unlocking and locking the vehicle with the horn (so-called US -. Style)
1.Select STG 09 (vehicle power)
2.STG Lange Coding -> Function 07
3.Byte 5
4.Enable Bit 1
5.Enable Bit 4
: additionally possible to make DWA acknowledgment in the comfort menu visible
3.Byte 5
4.Disable Bit 2
Adaptation of DWA:
3.Channel 3
4.Value set in accordance with 0 = frequency modulated alarm signal 10 Tamperalarme (USA 5min) 1 = intermittent alarm signal 10 Tamperalarme (EU, 5min) 2 = frequency modulated alarm signal 1 tamper alarm (USA, 30s) 3 = intermittent alarm signal 1 tamper alarm (EU, 30s)
4. Köşe dönüş farlarını aktive etmek:
In the central electrics You have the option at the Skoda Superb 3T to activate the cornering light. It is then driven through the fog lights.
3.Byte 14
4.Enable Bit 7
additionally possible: limit cornering time
3.Byte 12
4.Enable Bit 4
5. Yüksek süratlerde farlar için otoban modunu aktifleştirmek:
In the network control unit gives you the option when Skoda Superb 3T activate the motorway light. At high speed, then the illumination of xenon is adjusted automatically - the light cone is narrower in width and thus longer.
Motorway mode uses the large amount of light and optimized side and ground lights of the xenon plus pig launcher. Using sensors, a vehicle electronic system continuously analyzes the speed of the vehicle. After a short time above 110 km / h the system is based on highway driving and automatically switches from low beam mode in motorway light mode. The special position of the diaphragm in the xenon plus headlights additional light will be focused by an aluminum reflector and thrown far ahead of the vehicle without dazzling other road users, however. The sight is more than doubled: from 70m in low beam mode at 150m motorway light mode. This increase in the visibility means at a speed of 130 km / h has a gain of 2 seconds to react to objects in front of the vehicle can. Motorway mode thus increases driving safety significantly.
3.Subsystem: Rain / Light Sensor
4.Byte 02:
+01 For motorway light
+02 for rain light (if both are required thus: 03 as HEX entry)
-Otomatik Kilitleme ve Kilit Açma:
In the central electrics You have the option at the VW Golf VI, the automatic locking and unlocking of the car to activate or deactivate
3.Byte 0
4.Bit 1 (Auto-Unlock)
5.Bit 2 (Auto-Lock)
6. Fren Yardımcısını Ayarlamak:
In the braking electronics gives you the option when Skoda Superb 3T adjust the brake assist. Thus, the response of the brake pedal changes. (delayed faster)
1.Select STG 03 (brake electronics)
3.Channel 9
4.Value 2 change (default: 0)
7. Gündüz farlarını kapatmak:
In the central electrics You have the option at the Skoda Superb 3T turn off or disable the default daytime running lights
3.Byte 11
4.Disable Bit 2
8. Ayak Aydınlatmanın Ayarlanması:
In the central electrics (vehicle electrical system) gives you the option when Skoda Superb 3T to activate the footwell lighting while driving.
3.Byte 12
4.Value to +20 increase (standard: 54 to 74 HEX) when encoding unsuccessful; can still be tested the following:
5.Select STG 09 (vehicle power)
6.STG Lange Coding -> Function 07
7.Byte 20
8.Enable Bit 0
yet possibly adjust brightness:
3.Channel 27
4.Adjust Value acc. Decimal (1 to 100%)
9. Aracın Sabitlendiği Hızın Yol Bilgisayarın Gösterilmesi:
In the dash panel insert (KI) gives you the option when Skoda Superb 3T to display the set speed. Thus, in the field of CCS (cruise control indicator) / cruise control is shown the set speed accordingly. Only possible with software version 0406
1.Select STG 17 (dash panel insert)
3.Select channel GRA-high display
4.Put on active channel
10. Emniyet Kemeri Uyarısı
In the dash panel insert (KI) gives you the option when Skoda Superb 3T deactivate the seat belt reminders
3.Byte 1
4.Disable Bit 1
11. Yokuş Kalkış Desteği’nin Süresini Ayarlama:
In braking and ABS control unit gives you the option when Skoda Superb 3T adjust the function of the Hill Hold Assistant (Hill Start Assistant)
Coding:
1.Select STG 03 (brake / ABS)
3.Select Berganfahrhilfe or channel 58
4.Fit Function:
0 = Berganfahrhilfe "normal"
1 = Berganfahrhilfe "early" (starting at low speed)
2 = Berganfahrhilfe "late" (starting at a higher speed and a slipping clutch) <- for example, towing
12. Tek Dokunuş Sinyal Sayısını Değiştirme
In the central electrics You have the option at the Skoda Superb 3T adjust the Zylkus of comfort blinker. Value range 1-5 possible (ie between 1x or 5x flashes per tap)
3.Channel 13
4.Adjust Value: 1-5 Value 3 (standard - 3x blinking)
13. Ani Frende Dörtlülerin de Yanması:
In the network control unit gives you the option when Skoda Superb 3T Notbremsblinken the property via Blink - and brake lights (Adaptive Brake Light) activate
3.Byte 16
4.Enable Bit 1
5.Bit 2 Activate additionally possible: even when towing a trailer possible
6.Byte 23
7.Enable Bit 5
14. Sis Lambalarını Gündüz Farı Gibi Kullanma:
In the central electrics You have the option at the Skoda Superb 3T to activate the fog lights as daytime running lights
3.Byte 14
4.Enable Bit 1
More customization options regarding daytime running lights.:
Daytime running light inactive when the handbrake
3.Byte 11
4.Enable Bit 0
Daytime running active only in light switch position AUTO:
3.Byte 26
4.Enable Bit 4
Daytime running tale available:
3.Byte 26
4.Enable Bit 5
15. "
Rain Close” Aktifleştirme(Yağmur Yağdığında camlar ve açılır tavanın otomatik kapanması)
In the central electrics You have the option at the Skoda Superb 3T to activate the rain Close
3.Byte 4
4.Enable Bit 5
5.Enable Bit 6
6.Select STG 09 (vehicle power)
7.STG long coding -> function 07
Select rain and light sensor - RLS
8.Byte 0
9.Enable Bit 2
16. Far Yıkama Sisteminin Ayarlanması:
In the central electrics (vehicle electrical system) gives you the option when Skoda Superb 3T to disable or adjust the headlight washers (SWRA).
3.Byte 20
4.Disable Bit 5
More customization options regarding headlamp cleaning system.:
Headlight washers (SWRA) adapt Ansteuerverzögerungszeit:
3.Byte 05
4.Adjust accordingly delay time. (Resolution 50 ms)
Headlight washers (SWRA) adjust driving time:
3.Byte 06
17. Geri Viteste Sağ Aynanın Aşağı İnmesi:
In door control unit gives you the option when Skoda Superb 3T the drawdown to activate when reverse gear.
1.STG 52 (Türelektr. Beifahr)
2.STG coding -> function 07
3.Byte 4
4.Enable Bit 2
5.Enable Bit 3
18. Gündüz Sürüş Farlarını Özelleştirme:
In the central electrics (vehicle electrical system) gives you the option when Skoda Superb 3T adapt the daytime running lights (DRL).
3.Byte 15 Bit 6 (TFL separate lights - LED)
Byte 24 Bit 7 (TFL as a position light)
Byte 27 Bit 2 (TFL as a sidelight - is dimmed when low beam)
Byte 18 to 04 HEX
19. Gündüz Farlarının Parlaklığını/Işık Şiddetini Ayarlama:
In the central electrics (vehicle electrical system) gives you the option when Skoda Superb 3T dimming of the daytime running lights (DRL) percentage adapt.
Until 2011 model year
3.Byte 8 / 1A = 25%
Byte 8/32 = 50%
Byte 8 / 3C = 60%
Byte 8 / 4B = 75%
Byte 8/00 = 92% default
Byte 8/64 = 100%
From 2012 model year
3.Byte 24 / 1A = 25%
Byte 24/32 = 50%
Byte 24 / 3C = 60%
Byte 24 / 4B = 75%
Byte 24/00 = 92% default value
Byte 24/64 = 100%
20. Cama Su Püskürtüldükten sonra Sileceklerin 2 Saniye Sonra 1 Kez daha Çalışması:
In the network control unit gives you the option when Skoda Superb 3T to activate the function of wiping tears (Wipe)
3.Byte 1
4.Bit 3 Enable as possible: activation of the reversing wiping
5.Byte 21
6.Enable Bit 4
21. XDS(Elektronik Diferansiyel Kilidi)’yi Aktifleştirmek:
In brake control unit gives you the option when Skoda Supber 3T from BJ 2011 to activate the XDS electronic differential lock. The electronic differential lock XDS is an extension of the known EDL function. However, XDS does not respond to traction, but to the relief of the inside front wheel during fast cornering. From the ESP hydraulics XDS is pressure on the inside wheel, to prevent it from spinning. So that the traction is improved and reduces the tendency to understeer. The pressure level while moving about in the range of 5 to 15 bar. The driving idea is similar to a controlled differential lock in a weakened form. By the unilateral, precise brake pressure increase cornering performance is even sportier, faster and more accurately.
1.Select STG 03 (brake)
3.Byte 17
4.Enable Bit 3
22. Kadran Selamlama:
In the dash panel insert (KI) gives you the option when Skoda Superb 3T to activate a link test. With ignition on so the pointers go back again to stop and back. (Show effect)
3.Actively set channel for staging / staging
Çevrimdışı fanatikahmety
    • İleti: 97
Bu yazdığınız özellikleri Ankara'da nerede yaptırabiliriz? Teşekkürler.
Çevrimdışı deathbomb
  • Superb Tutkunu
    • İleti: 560
Ender, bilgi için teşekkürler. Yaptırmak istediğim özellikler var bir el atacak birini de bulsak super olacak :)
    • İleti: 7266
Alıntı yapılan: fanatikahmety;538933
Ankara'da üyelerin bu iş için para vermesine gerek yok:) Buluşmalarda kodlamaya da giriyoruz zaten. Şu an en son sürüm kablonun gelmesini bekliyorum, bir dahaki buluşmada muhtemelen kablo elimde olacaktır.
Alıntı yapılan: deathbomb;540406
Anadolu Yakası'ndaysan Ender Elektronik. Kendim uğraşırım dersen bir kablo al ömürlük olur zaten, neredeyse kodlama parasına kablon olmuş olur.
    • İleti: 97
Bir dahaki buluşmanın ne zaman ve nerede olacağı belli mi peki :)
    • İleti: 7266
Şu an için belli değil; belli olunca "Buluşmalar" alt forumunda duyurusu yapılıyor. Takipte kalın
Ender slm,
Ender-elektronik bu işi internetten de yapmaya başlamış. Sabit bağlantı, yapılacak tarafta vag-com ve Alpemix adlı bir program olması gerekiyormuş
Acaba nedir bu alpemix? Bulsak uzaktan yapabilir miyiz bu şekilde
    • İleti: 7266
Alıntı yapılan: viperking;540755
Ender slm,
Çok detaylı bilmiyorum; ama şöyledir muhtemelen: Öncelikle sende vcds'nin kurulu olduğu bir laptop olmalı, kabloyla da kendi bilgisayarını aracın obd portuna bağlamalısın; ardından da Ender Elektronik Alpemix ya da o tarz bir programla senin laptopuna uzaktan erişim sağlayarak kodlamayı yapabilir.
  • Superb Tutkunu
    • İleti: 560
Alıntı yapılan: enoktakenokta;540456
Teşekkürler Ender.
İstediğim 3 12 ve 13 numaralı özellikler sadece. Kablo baya pahalı, biyerde yaptırırım artık :)
Bu arada bahsi geçen alpemix uzaktan erişim programıdır.
    • İleti: 7266
Yusuf aslında kablo şu an 28 dolar civarında. Kodlamayı parayla yaptirsan 1 kodlama da olsa 10 kodlama da olsa 50-TL para vereceksin. Bu nedenle kablo alsan daha iyi olur bence.
  • Superb Tutkunu
    • İleti: 560
Alıntı yapılan: enoktakenokta;540856
28$'sa iyi 200-300TL'ler gördüm de ondan dedim. Kablonun yanında yazılımda var dimi?
Yazılım işi sakat olmasın, kullandığımız bişey değil sonuçta. Sen uyguladın sanırım, kullanışı nasıl?
    • İleti: 7266
Onlar güncellenebilir olanlar. Benim dediğime güncelleme olmuyor. Kabloyla yazılım cd'si de geliyor. Bizim arabalar trafiğe çıkalı fazlasıyla zaman geçtiği icin son sürüm kablo yeter zaten. Açılabilen bütün özellikler açılabilir.
Çevrimdışı Esariipek
    • İleti: 5850
Alıntı yapılan: enoktakenokta;540873
Yeni kablo bi gelsin okulun ana otoparkına çekicem arabayı VAG-COM KODLAMASI İLE GİZLİ ÖZELLİKLER AÇILIR. MÜR: ŞOFÖR  yazicam abi [emoji23] skoda gelirse buluşmaya gel beleş açayım dicem adam kafalarız[emoji23]
    • İleti: 7266
Alıntı yapılan: Esariipek;540964
Ender bunu beğendi:D
Çevrimdışı LA BEBE
  • Bir Angara Klasiği
    • İleti: 688
Bizim arabaya el atarız demi o zaman :D Kadran çok terbiyesiz selamlamıyo beni arabaya binince cık cık cık cık :D
